jet-hot headers 01 f-body
I just got a set of Jet-Hot headers with Y pipe and cats. I am gonna install them tomorrow. Is anybody running this set-up, If so any recomendations on installation? It is adverstised that O2 extensions are not needed, is this correct? i'd hate to start something and have to wait 5-6 days for parts. thank you.
Originally Posted by SouthFL.02.SS
Lots of people use Jet Hots.
You need O2 extensions for the rear O2's in the Y-pipe (to get them to reach) if you have not deleted them via edit, or if you're not using O2 Simulators.
Check out www.ls1howto.com for header install write up.
I have a pair of JetHot's and unless the changed the location of the collector and bung, you WILL need o2 extensions for the FRONT o2's or a set of bosche 13111's. The rear o2's fit with out extensions.
!LS1 11 Second Club
Bah, it's been a while, my bad. Front O2's are the ones that need extensions, as mentioned above. I replaced the LT's on my car a year ago, but I had run the extensions on them 3 years ago, so memory faulted.
as far as the install goes, I had to undo the left motor mount and raise the motor to clear the machining tab.
I have Jet Hot headers and installed them myself.
Remove the steering link and you'll have plenty of room.
You might have to notch the K-member on the drivers side, my one tube was hitting/rubbing. A little notching on with a dremel did the trick, been fine ever since (2+ years)
You will need 02 extensions. Only use factory GM F-BODY 02 SENSORS, if not you take the chance of getting slow switching codes...
Originally Posted by Billiumss
You don't have to do that at all........
