what afr are you running??? pole
LS1Tech Sponsor
On N/A vehicles I shoot for 12.6-12.8:1 at torque peak and 12.8-13.1:1 at hp peak and redline. Soem like to be richer then others though. Some liek to be leaner too. This is just a good starting point if you are not on the dyno or at the track to see were you are making more power.
With no other changes going from 12.6:1 to 12.5:1 at peak torque netted me 3bhp and ft/lb so I can say that 12.5:1 is best for my speed density mode 2000 LS1 (HSV R8 M6)
can anyone send me their maf calibration table if you are running hp tuners.... i am trying to run 13.1 - 1 also if you could send your ve tables..... i am not wanting to toss them at my car i just wanting them to compare to see if i am in line with the route i am going....hahha i need help lol
12.0 below peak tq
12.2 for peak tq
12.8 for peak hp
12.6 above peak hp
This AFR along with a slight increase to timing (1~3 degrees advance) netted me ~0.2 seconds and ~2mph over the factory tune.
12.2 for peak tq
12.8 for peak hp
12.6 above peak hp
Kleeborp the Moderator™
I run ~12.5 up to peak torque, where it goes down to about 12.44 (@ 4800 RPMs), and then I lean it out to ~13.0 for the rest of the RPM range. My car definitely likes being richer before peak torque...that's for sure. No track times to back it up though...
Even with leaning it out a bit up top, I'm still seeing 83% injector duty cycle with only full exhaust, a little intake, but still stock internals.
1 Post
very nice guys...i think i will try 13.1 and make a second tune for 12.5 i think my injectors maxed out this weekend......will need to upgrade.....any recommendations...?
