What pulley you use (Double Roller)
For all you guys out there w/ the Double roller timing chains, what else was required to use. I see on Speed inc's website that the ASP Pulley requres modification when used w/ the Rollmaster Double Roller timing chain, however the SLP pulley works w/ both Chain sets? Can you guys let me know what pulleys you are running, if you you know why you neeed it modified or cant use ASP, was there any other modification aside from spacing the oil pump or should i jsut forget the hastle and go w/ jsut a chain for the stock timing set?
thanks in advanvce
Speed Inc says PAP (?) and SLP wokr w/ but not ASP does that mean MARCH would work?/ yes or no thanks
thanks in advanvce
Matt where did you get the LS2 timing chain i cant find it anywhere? Do i go directly through GM and jsut order the LS2 timing chain or is there a specific modified one that will fit ours or something?
Retired Street Racer
You can get it from GM, that's where I got mine. Just a little something to think about...MTI uses the LS2 chain on their 427 motors. If it is good enough for that, it is good enough for a 346. The part number is 12586482. Let me know if you have any more questions
