are the silverado and the ls1 throttle bodies interchangable?
On earlier f-bodies it's a direct bolt on. However, on 00+ you will have to make a spacer to take up thorttle cable slack, if you have TCS your throttle cable should be adjustable. The truck TB has a smaller cam on the end like 98-99 F-bodies. I personally use one without any issues. I just made a spacer for the throttle cable at the gas pedal out of some brake line.
