Best Aftermarket Differential for 10 bolt?
I have a 2000 TA with an A4 and a series 2 carrier. I want to upgrade the gears from 2.73 to 3.42. The best way to do that seems to be to upgrade to an aftermarket differential. I know many of you will say save your money and upgrade to a 12 bolt but I just want to have a little mor fun on the weekends with the fair weather driver. Anybody have an opinion on the best differential and gears?
GM/Motive gears, properly set up, are the quietest. The T2R Torsen diff is the best for going around corners. If they still make it (do they??) for 10 bolts, the Truetrac is/was the best/strongest for straight line combined with handling.
