LS6 Intake part number
Old 12-24-2005, 12:58 PM
DarkHawkLS1's Avatar
Default LS6 Intake part number
Just wanted to clarify that I did in fact buy a LS6 Intake. I was told that it might be a LS1, because the EGR casting was there, but there is no hole or anything. It's not plugged or anything.
But I know that when I installed it, the bottom of the intake was (Flat), unlike the LS1 with the ridge going down the middle. That's the only insurance I have right now, just making sure with you guys.
Thanks
Old 12-24-2005, 01:01 PM
SSU's Drunk Typing Whore
Lithium's Avatar
Sounds like its an LS6.
What part number do you have on yours?
Old 12-24-2005, 01:04 PM
That's the thing, I've searched on GMpartsdirect, but it's not showing up. The only number on the intake show 815141, but I thought the part number should be longer than that.
Old 12-24-2005, 01:08 PM
Lithium's Avatar
No thats not it. Check on the drivers side of the manifold...by the middle injector - it should be there.
Old 12-24-2005, 01:09 PM
ok...hold on, going to go check.
Old 12-24-2005, 01:18 PM
Alright, there's no part number. No engravement or numbers.
Old 12-24-2005, 01:21 PM
Lithium's Avatar
wierd...
If it looks like this your good.
http://www.ls1howto.com/howto/geniii...//IMAGE009.jpg
Old 12-24-2005, 01:24 PM
Yep, I've seen that pic before, and used it as a reference.
Mine is flat just like that, just no part number....
Thanks man
Originally Posted by Lithium
wierd...
Old 12-24-2005, 01:27 PM
Lithium's Avatar
Thats still wierd...if it was there it would really obvious...huh.
