part i need help finding
Old 12-25-2005, 07:25 PM
FBGSU02's Avatar
Default part i need help finding
on ls1howto.com it says i need a (leak down spark plug hole fitting for air hose) does anyone have one they want to sell or know where i can get one thanks frankie
Old 12-25-2005, 07:33 PM
777's Avatar
Go to Autozone and get a compression tester kit for $20. It will have it in there.
Old 12-25-2005, 07:39 PM
Tally TransAm's Avatar
when you get the compression tester take the schrader valve outta the end
Old 12-25-2005, 09:26 PM
Ωmega's Avatar
https://ls1tech.com/forums/showpost....8&postcount=86
I used this, works real well. If you don't need the spring compressor, the air tool is only $24
