10 bolt going, need some info...
Old 12-26-2005, 03:03 PM
BlackLine's Avatar
Default 10 bolt going, need some info...
my 10 bolt is getting ready to bite the rocks. i have been looking around for a 12 bolt or 9 inch replacement.
my car is a street drag car. motor is stock for now (just purchased), its a 6 speed. but have plans for around 450-500 whp. first should i go with the 12 bolt or 9 inch. next should the eaton posi, spool, or a detroit locker.
Old 12-26-2005, 04:05 PM
blue01ta's Avatar
9". The posi, spool, or locker is up to you. I went with the spool.
Old 12-27-2005, 04:02 PM
BlackLine's Avatar
whats the best for a street drag car. i know a spool is just like a straight axle is the locker a good choice?
Old 12-27-2005, 07:15 PM
dailydriver's Avatar
If you can stand the noise around turns, the locker is your best bet. If not, (and if you want to put power down coming off turns better/smoother) then a Truetrac should be your choice (but it's not as strong as a locker and will not launch as well from a stop going straight).
Old 12-29-2005, 09:50 PM
BlackLine's Avatar
how loud is the noise.
Old 12-30-2005, 06:01 AM
EPP
EPP's Avatar
The Detroit Locker can have a fairly loud ratcheting noise. You cannot get the 9 inch as an ABS only rear, if you have ABS/TCS (4 channel) then you're all set. The people who have ABS only usually order it anyway, and just accept the fact there ABS won't work.
At your hp level, the Moser 12 bolt with the Truetrac is a good way to go. I have sold dozens of these rears, and most people don't have any problems. For a product that is beat on, that is pretty good! Bob
Old 12-30-2005, 06:33 PM
BlackLine's Avatar
whats the price difference between a 9inch with a locker and the 12 bolt with truetrak?
ill also need the 4 channel....
Old 12-31-2005, 12:09 AM
SSilverSSurfer's Avatar
i was told a 9inch is a tad heavy and you should have no prob with the 12bolt
Old 12-31-2005, 06:06 AM
EPP
EPP's Avatar
Smile
The price is virtually identical. With the 12 bolt, you pay for shipping when the Moser 12 bolt arrives. With the Moser 9 inch, you pre-pay for shipping, and the Moser 9 inch arrives by UPS. Bob
Old 12-31-2005, 10:42 AM
ss01layinwheel's Avatar
well, 9 inch's are notorious for robbing power(everyone who races pretty much knows this). However you will never ever break it. the 12 bolt is an extremel strong rear, probably right up there with a 9 inch. personally i have never heard of anyone having a problem with breaking a 12 bolt. I am probably goin to bu a 12 bolt if i ever get the money together.
Old 12-31-2005, 12:20 PM
sprayinss's Avatar
i have a 12 bolt and wuldnt trade it for anything,9 inch rears are good too,both are very stout,u will be happy with either one,jmo
