Who makes braces for wheel stands to save the oil pan?
Wolfe, Madman? I have seen them on here and couldn't find them on either site. any help would be appreciated.
Yeah. i will do that after the 1st of the year when everyone gets back to work.
Is anyone running these? any pics?
I was looking for the madman ones, I read about them on here a while back but now I can't find them. I think they were just bolt on bars, nice, simple and easy to install. I'm going to be needing a set for spring time so I hope someone will post up about them. If I remember right he only made a set amount of them, so I don't know if he still has any or would still make them. I'd feel a lot better about getting lift off if I had a little protection for the landing lol.
Wasn't the price of these SYA bars kind of high though? I could be wrong, but I was thinking they were about $400-$500?
Then again, it would be less expensive than replacing anything in the bottom of the engine.
Originally Posted by MADMAN
The bars run $100.00 and are disposable. You smash them instead of the headers and oilpans.
Man, I was way off... I thought they were more expensive.
This is for two bars correct?
Originally Posted by JL ws-6
There's no way to make a set for the stock K member is there? I'd be intrested for a set this spring.... just in case. Not sure what's gonna happen when I hit the transbrake button off a 5000 converter....
Race your car!
Understood.. but a set of bard to absorb the impact wouldn't hurt. I plan to swap the whole front end over to LW stuff... just don't wanna have to do it because I screw up and let off instead of pulling 2nd gear and trying to ride it out, should the front end come up in a big way.
R series shocks for the front are probably gonna happen as well before I get to the track.. will the set compression with a stock K be enough to not have to be concerned? Car made 403 rwhp cam only M6, now has a good set of ls6 heads on it, probably in the 430 to 450 rwhp range before the th400 goes in... after teh swap I'm guessing about 370 to the tires give or take. Maybe I'm not even making enough power to be concerned?
