Pontiac Firebird 1967-2002 - Easiest way to get at the Fog Lights in a 2K T/A?
Tram
12-27-2005, 01:51 PM
Just what the title says? What is the easiest way to get to them and remove them?
2K2WS6TA
12-27-2005, 02:17 PM
Look under the front of the car, there'll be 4 button fasteners, remove those, and pull back on the plastic, you should be able to see/reach the foglight mounting brackets, use a 10mm gear wrench to get the bolts out, remove the electrical connector, and the lights come out
Tram
12-29-2005, 11:43 PM
Wow.. that doesn't sound soo hard.. :)
y2k_ta
01-01-2006, 09:56 PM
Your other option would be to pop the headlights. That gives you just enough space to slide your hand down in behind the foglights. You can grab onto the back of them this way. Not nearly as easy as 2K2WS6TA's suggestion, but if you don't have any tools around it works :)
2K2WS6TA
01-01-2006, 10:33 PM
Honestly I have no idea how the hell anyone gets their arms down there that way :confused: I tried it when I first got the car, and there is no way in hell my arms are fitting down there (and yes I have fairly skinny arms)
y2k_ta
01-02-2006, 03:24 PM
I've done it at least four times. I have small hands and skinny arms, and it's a tight fit.
Danny2tek
01-02-2006, 07:20 PM
I've stock my hand between the washer fluid tank.
wilddawg
01-02-2006, 08:18 PM
same here I do that to change the bulbs
Weezzer
01-03-2006, 11:23 AM
Pull the bezel (black plastic cover) off the lights (three screws) and it will leave you with a large hole to reach down into.
y2k_ta
01-04-2006, 05:21 PM
I'll have to try that too. That sounds like a good idea.
BURN'EM
01-05-2006, 08:48 AM
turn the lights on when they go up you have plenty of room to reach down
TNTramair
01-05-2006, 09:05 AM
are you tryin to get the housings off or just the bulb????
cause i can get my bulb right through the air vent located right under the fog lamp. if its the housing, than use what everyone else has suggested...pop your lights up...remove headlight bezel and its easy access.
