Ssra???
Old 12-28-2005, 06:09 PM
Andrew_071's Avatar
Default Ssra???
OK my Camaro has a Loudmouth exhaust system, an airlid, K&N air filter, Ls1 Edit, 3.73 gears, 160 thermostat. Anyone know about how much power I can expect if I install a SSRA kit?
Old 12-28-2005, 07:27 PM
!LS1 11 Second Club
SouthFL.02.SS's Avatar
+1 mph trap in the 1/4.
Old 12-28-2005, 07:29 PM
SSU's Drunk Typing Whore
Lithium's Avatar
gains of 15rwhp at speeds above 60mph.
Old 12-28-2005, 07:42 PM
Andrew_071's Avatar
Thanks for the info, that 15 RWHP comment has made up my mind, I'm buyin' it tonight.
Old 12-28-2005, 07:43 PM
Andrew_071's Avatar
Oh yeah. Anyone know what website sells the SSRA for the lowest price?
Old 12-28-2005, 07:46 PM
!LS1 11 Second Club
If that were true, everyone would have one.
I had one. 117 vs. 118mph on my cam only setup. About as good as a little tailwind. It's a little on the voodoo side of things, but eh, what the heck, every little thing helps I guess.
Old 12-28-2005, 07:48 PM
Andrew_071's Avatar
Hmm. how much RWHP would you say it gave to you?
!LS1 11 Second Club
After I posted this, the manufacturer included longer screws in the kit. Hehehehe....
Old 12-28-2005, 07:49 PM
Andrew_071's Avatar
What are the longer screws for?
!LS1 11 Second Club
Being that a chasis dyno is stationary, who knows?
Old 12-28-2005, 07:50 PM
!LS1 11 Second Club
To make sure it doesn't fall off when you drop clutch @ 5000 rpm.
Old 12-28-2005, 07:52 PM
"All Motor 9 Second club member"
TXCAMSS's Avatar
It is a very worthwhile mod IMO. The HP gains won't show on a dyno, but it is worth at least a tenth in the 1/4 and a bit more in better air.
If you are going from no air induction modification to a SSRA, you will be very pleased.
I got one of the early versions that were made of brittle Polyethylene and not real durable, but it is currently in use (pieced together after many repairs) and is serving a good purpose. The metal version would be your best bet.
Good luck!!
Old 12-28-2005, 07:53 PM
!LS1 11 Second Club
I put it back on the car, until I ripped off the front portion again on a parking curb. After that, I used nuts and bolts and a ton of black masking tape. Worked like a charm.
Would I buy another? Maybe.
Old 12-28-2005, 07:55 PM
!LS1 11 Second Club
Good luck!!
See pic above.
Old 12-28-2005, 07:56 PM
Andrew_071's Avatar
Ah ok. Thanks a lot for the info guys. It should be a decent mod for my car cause the only induction I have is from the SS hood and we all know how great that works.
Lithium's Avatar
So 10 to 15hp is not true then? 60mph and above??
Old 12-28-2005, 07:59 PM
!LS1 11 Second Club
I don't know. Sounds like a very specific claim.
Maybe?
Old 12-28-2005, 08:34 PM
Andrew_071's Avatar
I had the free-mod before but it pulled too much dirt into the filter so i had to close it up, but when I had it it made a difference I could actually feel, so 10-15 HP sounds pretty reasonable to me.
Old 12-28-2005, 09:45 PM
TXCAMSS's Avatar
If dirt in the air filter is a concern, skip the SSRA. If you want to squeeze every ounce of HP from your car (as most here do) then the SSRA is proven. The 10-15 rwhp is evident in track ETs, but not on a dyno. It is worth the $$$ IMHO.
Old 12-28-2005, 11:04 PM
Roarin_8's Avatar
Went from 106 to 111.7 at the track with a stall and the ssra. I know that the stall didn't give me the full 5mph gain.
