School me regarding spring wear with example inside using two Lunati grinds
Old 12-28-2005, 11:31 PM
!LS1 11 Second Club
SouthFL.02.SS's Avatar
Default School me regarding spring wear with example inside using two Lunati grinds
Advertised Duration IN/EX: 298/286
Duration @.050 IN/EX: 230/237
Gross Valve Lift IN/EX: .544"/.543"
Lobe Sep Angle / Intake Ctr Line: 112/108
Valve Lash IN/EX: Hyd/Hyd
RPM Range: 2800-6000
68/49
Advertised Duration IN/EX: 298/301
Duration @.050 IN/EX: 237/242
Gross Valve Lift IN/EX: .595"/.595"
RPM Range: 3000-6500
61/59
Just as an educational example, would the softer lobes of the higher lift cam be easier on valve springs than the aggressive exhaust lobe of the lower lift cam, given the durations we're looking at? The subtractions of .050 from .006 are bolded.
Old 12-29-2005, 12:02 AM
Beast96Z's Avatar
The added lift is going to take your springs closer to coil bind, but that's what they are intended for. That's why there are coild bind limitations on the spring. I believe the aggressive opening and closing of the stiffer lobe is going to have a bigger effect on spring wear vs. lift. Both cams would last a while, but your exaust springs would go out long before your intake springs on your first cam listed. I personally wouldn't run the second cam because of the very lazy lobes it's ground on. This in conjunction with it's size would make it a pooch on the low end.
Old 12-29-2005, 12:05 AM
!LS1 11 Second Club
Originally Posted by Beast96Z
The added lift is going to take your springs closer to coil bind, but that's what they are intended for. That's why there are coild bind limitations on the spring. I believe the aggressive opening and closing of the stiffer lobe is going to have a bigger effect on spring were vs. lift. Both cams would last a while, but your exaust springs would go out long before your intake springs on your first cam listed. I personally wouldn't run the second cam because of the very lazy lobes it's ground on. This in conjunction with it's size would make it a pooch on the low end.
Thanks. Exactly the kind of info I wanted to hear.
I'm forcing myself to learn how to read a cam card (beyond .050 duration, lift and lsa) and learn more about valve events. After 6K posts, you'd expect me to know a 'lil more beyond calling out "F13 is what you need!"
