What can't be cut inside the car
Lookin at my new found tool (angle grinder) and I need to practice cutting some stuff.
I see some misc stuff inside the car that I dont need anymore, like where the rear seats mount, air bag sensor mount, etc
But wondering about anything else inside there that might need to stay for structural support. Not Cage at this point.
Any pix of things you cut out?
I cut out all the rear seat mounts, and rear seat belt mounts, TTop holder mounts, amd all most of stuf under the center counsle.
If you wanna save a little more weight, use a spot weld cutter. It will problably be a lil faster too.
You can get one from www.Mcmaster.com its part #4096a11
im sure by the time you get done with this new tool you will have 4 dozen used cutting blades and one hella fast LT1 pop can shell for a car
( meaning its gonna be cut down thin and light )
I didn't really cut anything out of the interior of my car but I did remove all miscellaneous brackets that were spot welded. I was thinking about cutting out the side panels where the rear speakers go but I figure I would leave that in for structural integrity.
One thing I did which may have been a couple of pounds was to cut out areas of fiberglass behind the door panels and cut of out some areas of excess material on the hatch.
Sweet Cheeks
Originally Posted by Dear John
Any pics of the hatch? How's that for structural integrity?
