View Poll Results: Which one?
HO Intercooled with P-1SC - Features: 8 psi of Boost, 55-60% HP Gain, Standard Two Core Intercooler
2
6.06%
Stage II Intercooled with P-1SC 10-14 psi of Boost, 65-85% HP Gain, Standard Twin Highflow
3
9.09%
Stage II Intercooled with D-1SC 12-20 psi of Boost, 75+% HP Gain, Standard Twin Highflow
28
84.85%
Voters: 33. You may not vote on this poll
Which Procharger
Which Procharger
P600B is out of question
Is the D1SC worth the money?
Is the twin intercoolers worth it? Since everyone is putting a bigger single in, would it be cheaper to get the one with the 2 core and swap it for a bigger one later. What is the real differences between the kits?
The LT1 ATI ProCharger twin hi flow kits, the P-1SC and the D-1SC both come with the 12 rib pulley. The standard non twin hi flow kits come with the 8 rib pulley's.
You can run the D-1SC at relatively low boost levels on the LT1, so if you purchase one and only want to run 7 psi of boost, you can indeed do so. It is all in the pulley size that the ProCharger is spec'd out with.
You will need 42lb fuel injectors, a 255 litre in tank fuel pump, and tuning.
I recommend the SVO (BOsch) 42lb fuel injectors, a Holley pn# 12-914 "forced induction" fuel pump, and a good dyno tune. Bob
Exotic Performance Plus, I know you guys have pretty good deal on ATI's for the LT1 boys like myself, but say could I order a kit from you guys and not get any type of intercooler with it. I plan on building a FMIC setup and I would not need a intercooler with my Procharger, Can you guys sell the kits a little cheaper if we do not desire a INtercooler with it???????
You are indeed correct. Actually both the LT1 twin hi flow kits, the P-1SC and the D-1SC both come with the 12 rib pulley. The standard non twin hi flow kits come with the 8 rib pulley's. Bob
Originally Posted by orangeapeel
F1 or F2 procharger?
