how much i pipe with hooker catback?
Hey guys. I have the dynomouth exhaust right now, but am going to switch to hooker b/c I am going to get longtubes in the near future.
How much extra pipe does the hooker catback come with - because I'm going to have to cut off my exhaust in front of the current bullet muffler. That's about 4 inches from the y-pipe, which is not much room.
Will I have to get a small piece of straight pipe, or does the hooker come with enough pipe to go to the y?
Thanks for all your help!
!LS1 11 Second Club
I would think that it comes with as much I pipe as your current LM, to mate up into your Y-pipe. Is your Y-pipe welded to your I-pipe? Or is you bullet welded on to the merge of the Y-pipe?
I don't see what the problem is. You shouldn't have to cut off anything, just undo your LM and put on the Hooker.
I have Hooker LT's with no cats, along with the Hooker cat back. I've had the Hooker cat back 4 1/2 years no problem. When I put the LT's in and removed the cats I had to put a Dynomax 24" in the the I pipe to control the rasp. If you have a flow through bullet in the I pipe think about leaving it in!!!
I plan on keeping my cats however.
Thanks again guys!
