axle swap in a 10bolt?
is it ok to swap axle in a stock 10bolt? if so which spline? i was thinking of going with some Moser axles but was wondering if it was worth it
Well Moser axles are stronger than stock, and they are only $240 for a set of C clips axles. However the down fall of the 10 bolt at least with most of my customers is the physical size of the ring gear. With high HP & slicks no matter how strong the axles are and no matter how strong the posi is 10 bolts just destroy ring gears, usually the pinion just rips teeth off the ring gear
well i know in an auto car the 10bolt is likey to go then an m6 car....will replacing the axles and gears make it more vulnerable or less...my buddy has a stock M6 10bolt in his 408 firehawk(which is an automatic) and has had no problems with it
all i know is that a auto is easier on the 10 bolts then the manuals. a lot of cars into the 10's and i know of 1 that went a high 9. I just added a t/a girdle and stud kit and havent had any problems out of it(knock on wood). Im going back to the track next weekend looking for 11's out of mine, i just make sure i have enough money in the bank for another 10bolt.
--Matt
--Matt
well i should definitely see 11's with my new set up....i thought my rearend was done cause i heard howling but my pinion nut was backing out..LOL i got so damn lucky...i guess thats mod money right there
Originally Posted by sprayinss
man skip the 10 bolt mods and buy u a 12 bolt,its the best money i have spent on my car,jmo,goodluck
I put in the moser axles because my axle bearing **** the bed, no problems since I installed them and put the 3.73s in there. I wish I had the money for a new rearend put now I'm on a mission to see how far this 10 bolt will hang on.
