HEI spark plug gap??
I tried searching... sorry.
what plug gap are y'all running with HEI? I just swapped one into my Jeep's straight-6, and would like to know how wide I can go. Thanks.
The plugs for my chev motor come pre gapped at .40. With a fresh stock HEI (aside from taylor wires and msd cap/ rotor) it seems to handle .55 ok. @.60 it started to miss when I wound it up past 4000 or so. Keep in mind the higher the gap you go with the faster you will burn out plugs.
Gotcha, rat. The motor won't see anything over 5000 rpm, so I'll probably go something like .045". I've always liked the middle-of-the-road approach. Thanks for y'alls help.
