222/222 cam - suggestions please
will a 222/222 .566/.566 112 LSA cam work well in a modified 5.3? It will have new valve springs, headers, no emmissions, high flow MAF, and a retune. The engine will go in a small 3300# truck with a TH350 transmission (shift kit). How will this cam act (i want it to be streetable)? what kind of hp/tq can this make? lopey idle? Thanks everyone!
i am going to replace the stock valve springs with ls6 ones, will these work fine with the cam lift and can i use stock push rods and lifters (59k miles)? are these springs direct replacements for my stock ones where i can use my same retainers and locks? any other modifications needed to make this cam work?
Orangeapeel, the truck is so light because it is a little 1950 chevy farm truck (rcsb) like the trucks at the Old Navy stores.
Thanks for replys! Any other suggested mods to this motor are welcomed!
50 Check out my sig. My hp figures are low, but the torque is killer. Changed some things around just havent been back to the dyno. DO a search under my name I posted in the Dyno section. Later and Enjoy. John
