loss of power?????
Has Unresolved Sales
loss of power?????
ok i have a loss of power when i try to punch it from 60mph, it juss doesnt respond. and from 70mph it sort of responds. what can be wrong? anyone? anything below 60mph the car pulls like a raped ape.
could be cai dirty, usally plugs and wires will couse a miss at a idle or a jerk under a load with the rpms going up sounds like trans becouse if the rpms are going up the motor is turning just not getting to the tires for the pull when you installed the trans did you check the fluid after you drove the car for a few miles if not you might be running low on fluid that would couse your problem
