help, coolant dripping from the back.
I put the head studs in and changed the head gaskets, but there is coolant dripping down from what it looks like the drivers side, it starts after the car reaches temperature and it smokes from in between the firewall and the motor. The coolant on the ground is clean and there is no smoke coming out the exhaust so it doesnt look like its a head gasket leak. Where is it coming from? Is there a hose or any connection that I missed? I cant really see it from the bottom of the car or feel it from the top w/ my hand. Please help.
There are the two coolant blocks at the tops of the heads in the rear - maybe they're not on or tight ? There are a matching pair of them at the front of the heads for the coolant crossover.
Know the ones I'm talking about ?
Rob (Bad30th)
Rob (Bad30th)
