Any 383 Strokers running the G5X3 cam?
Old 01-02-2006, 09:38 PM
AlohaC5's Avatar
Default Any 383 Strokers running the G5X3 cam?
I'm trying to find out what the estimated rear wheel horsepower and torque would be for a 383 stroker running the LG G5X3 cam, and see how it compares to my setup with the F13 cam. They are both great cams; however, I like keeping my lift below .600. I'm thinking about adding the FAST LSx intake with a NW 90 TB next.
I would appreciate it if anyone running this setup (or the G5X4) can post their dyno sheet. I'm not trying to go for "max" power - the primary purpose of my setup is for road racing (HPDE/TT) events where low end torque and a relatively high/flat torque curve from 2500 to 6500 RPMs are ideal. Thanks!
Old 01-02-2006, 09:43 PM
SideStep's Avatar
I would like to know also....
Old 12-14-2007, 06:20 AM
Switchbarrel's Avatar
Default 383 w/ G5X3
Alright, I searched like a good boy and found this old thread. Unfortunately, no results. I'm hoping things may have changed in the last year or so since it was first posted.
Any 383's running the G5X3? If so, parts list and results requested. Thank you.
-Rick
Old 12-14-2007, 08:04 AM
SSdreamz's Avatar
whats the specs on the G5X3? i was wondering if my custom cam was similar
Old 12-14-2007, 08:29 AM
1999ssls1's Avatar
I think 240 244 on a 112. Not sure about the lift though
Old 12-14-2007, 08:31 AM
c5_ls1_6spd's Avatar
wouldn't a G5X3 be too small for a 383?
Old 12-14-2007, 09:56 AM
Bryan @ Speed Inc.'s Avatar
the G5x3 is 234/242 112 or 114 - lift is approx. .600/.610
i would think it would work VERY well in a street oriented 382.
however, you may see a little better performance using a cam that's specifically designed as a "stroker" cam.
we have a 238/244 114 that works really well in anything from a 382 to 427's.
we've seen around 520rwhp, in a 427 motor through an automatic trans with that cam.
Old 12-14-2007, 09:59 AM
that's probably closer to the x4. it's on a 111lsa... and that's all i know about it.
Old 12-14-2007, 03:34 PM
Sigforty's Avatar
I thought you had a bigger cam then the f13. The f13 should be 230 232 with under .600 lift.
Old 12-15-2007, 10:46 PM
Hi Bryan-
I'm interested in torque numbers mostly. My intended platform is my daily driver '01 Z06 which is currently wearing AFR 205's and a ported FAST90/LS2 TB setup. Might you have any numbers or preferably dynographs from the cam you mentioned in an LS6 382/383 combo? Thank you.
-Rick
Quick Reply: Any 383 Strokers running the G5X3 cam?
