Its time for something better than a 10 Bolt
I have a 98 M6 with ASR. Im guessing that I have a 4 channel ABS? Anyway, i want a 9" because they're strong and because you can have several centers laying around for different ratios. My friends 10 year old son changes his center section on his bonco. That screams easy to work on to me. Who makes a 9" KIT that will work with ASR and ABS. Also, what else will i need? Will i need to shorten the driveshaft? Will i need any type of swaybar mounts?
If yall think im better off with a 12 bolt then i guess i'll go with that. Is there anything else that i need to put the 12 bolt in and have a working car again?
I drive my car every day and take it on long trips often. I take 700 mile round trips often.
Thanks for everything.
Moser sells 9" rearends with ABS and TCS. The driveshaft does not get shortened, the stock one works. 3" muffler clamps work to reinstall the rear swaybar. You will need a Napa 447 U Joint, to go from your driveshafts 1310 yoke, to the Moser 1350 yoke.
$2,400.00 (includes shipping) through me will get you the Moser 9 inch with the Truetrac or (your choice) Traclok posi, with ABS/TCS. Bob
If everyone complains about moser 12 bolts and strange 12 bolts making noise and being improperly put together then why dont they just use the 9"? It sounds to me like they're a heck of a lot more problem free, and God forbid they do send you a mucked up center, its a lot easier to just yank it out and carry it under your arm to someone who knows what they're doing. So its pretty much a 100% bolt-in item? It works with 4 channel? There are no fitting problems? It comes with everything i need to install it and i dont have to send anything off before hand?
