positrac
Old 01-03-2006, 12:49 PM
bigwillie's Avatar
Default positrac
So I got a 2000 ss last month. Haven't started on the mods yet, but I noticed that when I turn off the trac control and powerbrake the car, only one wheel spins. Does a 2000 ss have some type of LSD or positraction? If it does, why only one wheel spin?
If not, I suppose that needs to go on the list when I do gears and tranny mods.
Thanks for the help!
Old 01-03-2006, 01:04 PM
777's Avatar
IIRC all of the v8's came with some type of posi. Your posi is probably just burned out and needs replacing or upgrading, thus the one wheel spin.
Old 01-03-2006, 01:06 PM
1994Z28Lt1's Avatar
well it should have a limited slip diff from the factory which uses friction discs, but the previous owner might have burned them up or possibly from lack of diff oil changes gm recommends every 10,000-15,000 miles haha and possibly not known to add the limited slip additive that must be added to the oil so your clutch pack will work properly
Old 01-03-2006, 01:55 PM
Swang's Avatar
Location: Hometown:Mount Carmel, IL Current: Las Vegas, NV
try changing your fluid. might as well try that before you get into uber expensive ****.
Old 01-03-2006, 02:17 PM
bigwillie's Avatar
Default Thanks. I will try
the fluid replacement.
But I wonder how expensive a new lsd unit would be... If I'm going to do gears anyway, is there alot more involved with a new lsd?
