can this cut off 1/2 second?
my best has been a 13.50, dont have many mods really.
with some LT's and drag radials, would that cut off that 1/2 second i need to get into 12's?
^ thats easy to say with a factory beast! every time I see your sig I feel envy. But most LS1s don't make 321 to the wheels with a lid only. That's like... 310 stock? maybe more.
Location: Hometown:Mount Carmel, IL Current: Las Vegas, NV
well the day i ran that 13.50 it was a pretty cold night..
in the summer the best i could pull off was a 13.62
i would do better at sea level but im at 4400 ft elevation, but i am worried about drag radials and breaking the rear end...
Now it becomes a little more clear...you are running at elevation. If I remember right it is something like 3% of your power that is lost per 1000 feet of elevation. If you can best your 60 foot time by approx .15 second by the installation of the drag radials (possible) then the long tubes should net you a few more tenths in et so there is your half second. (2*-.15)= -.3-.2=-0.5)
Originally Posted by Swang
mine did 320 and its a 2000. so thats no LS6 manifolds, or intake. thats with just a lid on a pretty hot day.
BTW, in theory outside temp should make no odds to the readings (or at least minimal) as there should be correction factors used to equal out atmospheric conditions, that's if it's been corrected to SAE as opposed to STD.
Tech Addict
Originally Posted by 777
You shouldn't break the rear-end with stock power. If you are really worried about get some nitto's they don't stick as good as the others. There are tons of people on here that run sticky tires on the stock 10-bolt. No problems. Good tires alone should get you 12's.
Originally Posted by Rokko
I broke my rearend with just the mods in my sig, which are minimal, and I'm an A4. I was running DR's at the track with about a season and a half on it when the rear gave out.
that aint good...
Tech Addict
that aint good...
the thing is i have just enough money for my car payment as i work part time and am a full time college student :\
how much do new rear ends cost? installation fees? gears?
Tech Addict
Originally Posted by 2002_Z28_Six_Speed
WHAT?!?!?!?
How did you pull that one off? It must have been a drunk factory worker!
That ended up being around a $3500 bill that cost me a 50 dollar deductable. Again, first time I've been that lucky with a dealer.
Tech Addict
New 12 bolts start around 2k before install and assorted optional goodies.
