x4 vs t rex
Old 01-03-2006, 07:17 PM
little tee rod's Avatar
Default x4 vs t rex
last week i talked to a guy at lg motorsports and he told me the x4 cam they carry is bigger than the t rex ! i didnot think that was true but was trying to get info. he did also say the x4 would not clear stock pistons without fly cutting. i looked at thunder racing and they say there cam clears stock piston. may be he is right just trying to get moe info.
Old 01-03-2006, 07:21 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
...well, the X3 will fit on unmilled stock heads, as does the T-Rex. And since LG keeps their durations a "secret" it is hard to say whether or not it is actually "bigger". It probably just has more overlap* than the t-rex therefore the valvetrain events will be different.
Old 01-03-2006, 08:18 PM
SUX2BU's Avatar
The T rex is bigger and they both fit without fly cutting. but you should check p-v clearence with any big cam.
Old 01-04-2006, 02:10 AM
SmokingWS6's Avatar
the x4 should not require fly cutting. The car I tuned with it had stock heads, valves, pistons ect.
I was very impressed with this cam. Be prepared to spin the motor quite high though.
Old 01-04-2006, 07:08 AM
LS1 BU's Avatar
I have a good idea of X4 specs. It seems to be much smaller that the Trex. Maybe he was talking about a X5. I've heard there might be an X5 comming out?
