Aeroforce interceptor gauges
Does anyone know for sure if the coolant temp parameter works on an 02 F-body. Or which of the other parameters work/don't work.
Also, were would be the best place to mount just one gauge.
Thanks in advance for any help.
I have one of these gauges hooked up, i havent seen how it the parameters work on the road, but i have watched them when the car is idling since it is winter here. The only thing that it will not read is oil pressure. I am still figuring the gauge out, i dont know what long and short fuel trim is?I guess is something with fuel injectors but not sure, anybody know the diff? The gauge is badass though.
thx rob
thx rob
Originally Posted by 1998TA__1991RS
what about down by the cig lighter, whats the difference in the dual and the single one?
Originally Posted by Ferocity02
Someoneb who has one of these installed needs to sack up and tell us what the gauge actually reads off. Arctic, maybe you could just plug it in to the OBDII port and write down what parameters actually work on it. Thanks!
Thanks for the replies. I guess I'm leaning toward putting it down by the cigarette lighter. I'm searching for the cleanest, easiest installation. I considered the pillar, but I'm not sure I want it up there, and do they even make a one gauge pod?
Are there any good write ups (installuniversity style) for gauge mounting?
Good luck with your gauges/installations.
Too bad you missed out on my little sale. You can make them yourself though, assuming you have the material and proper tools. I will make another round in early April and will offer more materials.
