Head gasket / compression ratio ?
Old 01-03-2006, 07:59 PM
LS1-450's Avatar
Default Head gasket / compression ratio ?
Have my heads off, thanks to an overheating scare & am considering options.
Heads are AFR 205 (10.3:1). Is there any advantage in using a thicker head gasket? If so, which one & will the push rod length need to be changed?
