Suspension & Brakes - Help getting my 60' down
View Full Version : Help getting my 60' down
MattZ28
01-04-2006, 12:28 AM
Right now on my Mickey Thompsons I am hooking with no wheelspin at all. That may change when I flash the converter on spray...
My question is this - will the car leave the line harder with different suspension components even though it is hooking?
Right now I have LCA's (poly/poly), front swaybar disconnected, poly rear swaybar bushings/endlinks, poly torque arm mount, and boxed SFCs.
Torque arm choices are limited since I'm running duals....unless I get a Jegster or something.
Any input is appreciated :)
Thanks.
jimmyblue
01-04-2006, 09:20 AM
If it's not spinning, I'd expect no suspension-based
improvement. All suspension can do, is maximally
load the rear tires on launch. Sounds like you're
there (for present delivered RWT).
