T3 vs T4 (Turbine)
T3 vs T4 (Turbine)
Other than the greater flow and size what is the diffrance between the 2 housings. Assuming they are both the same AR and use the same trim wheel will one outspool the other?
example
If i had a t3/t4 TO4r with an .82 AR exhaust housing and a straight t4 with an .84 AR Exhaust housing will the t4 with the .84 outspool the t3 because of the increased flow allowed by the flange?
example
