finally!! carbon fiber pro-stick installed...
That will be sweet as well. i wanted to try and keep the inside of the car with the "stock look" for the street racing scene. The cage doesn't help though! LOL!!!
Race your car!
It almost looks like if you could have shimmed it up a little more, the console notch in the back could have been avoided some. I'm in teh middle of colecting the parts for a TH400 swap right now... and hte shifter is one of the last question sI have left. I am leaning towards a Hurst quarter stick with the pistol grip, I am told that the shifter itself is top notch.... but there's a B&M one that fits perfect in teh M6 console. I have a A4 top 1/2 console that's gonna be at my door in a week or so, but I'd rather be able to have something that looks totally stock..... for the same reasons mentioned above
I probably could have raised it up a little. as far as the nothcing goes it is as close as i could get it with out it hitting anything. I tryed to modify the stock slideing cover to slide with the shifter but it envolved to much cutting. I still want to go back in and cover up where it is cut out so you only see the handle sticking out. But you also have to be able to push the reverse lockout to shift into reverse. Usually street racin goes down at night so not to many people look inside the car.
As for the price i got the shifter and all for $250.00. the cover that comes with it is carbon fiber also, for those that don't want to leave the stock console installed. It took me about 1.5 hours to install this and adjust the linkage on the tranny. The reverse light hookup and neutral saftey switch were a breeze aswell.
I got it from the local speed shop. B&M has them on there site. Jegs and Summit i am sure has them also. They just came out.
you can get them that way. mine does not have that grip on it. just check with who ever you order it from and they will get you the correct grip.
