LS6 intake vs. FAST LSX
Old 01-05-2006, 10:55 AM
blue28's Avatar
Default LS6 intake vs. FAST LSX
I have a ported LS6 throttle body and LS6 intake and I'm considering the FAST 90mm setup or possibly the 78mm but I haven't been able to find and good comparisons between what I have and the FAST versions, basically I'm trying to figure out if it's worth $2000 bucks or if I would gain better using that money somwhere else.
other mods:
Hooker headers
comp cam
NX 150
Lots of traction upgrades
Old 01-05-2006, 11:04 AM
SSilverSSurfer's Avatar
what size is the cam? for sure your gonna get a awesome gain......but to answer your quesiotn yes its worth it
Old 01-05-2006, 11:06 AM
!LS1 11 Second Club
SouthFL.02.SS's Avatar
90mm is an improvement over the LS6, typical estimate of 15rwhp gain. Now, a 90mm LSX/Nick Williams 90mm TB combo is nowhere near $2000.
It's up to you if you want to spend about a grand on this setup.
Old 01-05-2006, 01:41 PM
monicaz28's Avatar
Yep, it's only a little over $1000 for the setup, and definitely worth it.
Old 01-05-2006, 03:15 PM
02TransAm/Batmobile's Avatar
i too was wondering if i should go with a fast intake/bigger throttle. . . in hot rod magazine (Jan 2006) in the article "Bolt-on LS1 Muscle: 5 Steps to 530 HP" read, "According to FAST, in just intake-to-intake comparisons, its LSX manifold is worth at least 20 Hp over a stock LS1 intake. Comp saw over 30 hp by combining the LSX intake with a larger throttle-body and Maf Meter." The test was done on a 99' Camaro hence no ls6 intake. I believe if you are runnin a bigger cam then a Fast intake is better than an ls6 by maybe 20 hp. And if you are going with this set-up, don't get a 78m, go with a 90/90 setup. Makes more sense if your gonna upgrade to a FAST, you should up the ante a bit with the openings. I also heard that the FAST throttle bodies are nothing but problems and a Nick Williams 90m throttle body is much better . . . . as to the question, "is it worth it?", for the longest time i was sayin to myself, "its an 02 ws6 ls1, keep it stock, its already bad ***", but then i said, "f*ck it!!!!, you only get to live once and, . . . its an LS1 DAMMIT!!!!!"
Old 01-05-2006, 10:43 PM
BAM-BAM's Avatar
i switched from the ls6 ported tb combo to a
fast 90 with the 90 nw tb
this was the only thing i changed and on the dyno i gained
27rwhp and 14rwtq over the ls6 ported tb combo
i thought that was ok for the money spent
just because i'm staying n/a with the car and every little bit adds up..
Old 01-05-2006, 10:56 PM
SUX2BU's Avatar
Thats a DAMN nice gain!
Old 01-06-2006, 08:29 AM
LS1-450's Avatar
In the stickeys there's a comparison of several intake manifolds. The point that stood out most to me is when the author states that he believes a lot of the power gained by using the 90 mm FAST intake when compared to the LS6 intake was due to the larger inlet opening. Seems to me that if the LS6 inlet were opened to say 81 or 82mm coupled to an 80mm throttle body could be a good power adder for even less money. I have opened my Weiand (similar to LS6 manifold) to 80mm & it looks like up to around 82mm is doable on the intake manifold. Spent around $160.00 for a used ported TB & did the manifold myself. Don't have a dyno comparison, but, for me it was the way to go. Oh, did the MAF ends too.
Old 01-06-2006, 09:03 AM
noblesramair's Avatar
I dont want to hijack this thread but does anybody know how much hp gain there is from a 90mm fast intake to a ported 90mm fast intake.
Old 01-06-2006, 09:23 AM
Benjamin Russick's Avatar
Hmmm. I'll have to lurk on this thread as I am considering a 90/90 for my set-up. Keep any input coming...thanks!
Old 01-06-2006, 09:51 AM
CarsRFun's Avatar
i dont personally think they are worth the cost.
Old 01-06-2006, 10:08 AM
!LS1 11 Second Club
My ol' setup went from 425/390 to 460/405 from an LS6 intake/SLP LT to FAST 90/QTP HVMC LT swap.
Old 01-06-2006, 10:39 AM
BAM-BAM's Avatar
just to add some info to my earlier post..
the gains i saw were on my 383 motor
the cam i have is a 611/619 242/250 114 through kooks 1 7/8 with some old absolute speed stage 2 heads
the only thing i changed at the time of the dyno was the intake/tb setup
Old 01-06-2006, 04:36 PM
Tenured Member
TPiS's Avatar
If any of you have a copy of this months Street Thunder magazine we did a test that will answer a lot of your questions.
tpis
Old 01-06-2006, 10:39 PM
SUX2BU's Avatar
tpis
is this a national magazine? i've never heard of it but wanna check out the comparo. would Barnes and Knoble have it?
Old 01-07-2006, 08:39 AM
LS1-450's Avatar
tpis
Can you scan & attatch the results or post a link to an on-line version of the article for us to look @?
Old 01-07-2006, 09:05 AM
Drew778's Avatar
tpis
Every car is different and no one knows how much your set up is, that might help
Old 01-07-2006, 06:43 PM
Rey Kirkman's Avatar
TPIS is about to market a LS6 intake that is adapted to receive an LS2 or aftermarket 90mm throttle body.
Old 01-07-2006, 08:14 PM
MadBill's Avatar
Here's a link: http://www.classicsandcustoms.com/car-club.asp
Old 01-07-2006, 08:20 PM
nokeman's Avatar
if tpis is putting out an ls6 to match a 90mm TB, would that be as good and see as good gains as the fast 90/90 set-up?
Quick Reply: LS6 intake vs. FAST LSX
