Changing setup, again, need opinions.
I am thinking about going ahead and doing heads. I was looking at the stage2 patriot ls6. What CC chamber should I go with? I would like to stay as close to the stock compression ratio as possible.
Here is the cam profil
230/236 595/586 112lsa
90/90 Fast,36lb inj, kooks race headers with dual elec cutouts, The usual boltons.
Fitting your criteria for CC, I say give Gunnar a call and get those on a 64-65 cc with 2.02/1.57. The 6.0 gasket used is a bit thicker than your stock gasket.
Gonna have to measure PTV.
Other option is a stage 1 243 PP
The heades are 62cc with stock graphite gaskets..Bad luck with Cometics.
Work done by ProStreet MotorSports in Md. (Phil99vette). Phil's speed density tune makes this baby purr.
