header install gas mileage tips
Just put those headers on. I saw 3-4 MPG increase when my headers and TD's went on. Tripped 2300 miles across the country at an average speed of 85 and still saw 23 MPG average. Before the headers, I averaged 19-20 MPG highway. And this is low compared to a lot of the A4 guys. Some of them see over 25 MPG daily.
Air filter, check tire psi, might as well rotate them as well while it's in the air if you havent done that in awhile. Not so much to do with the headers but a lot of people seem to forget about injector cleanings... just clean the whole intake system if you want, that will help with fuel mileage.
About to do the same to mine. Also going to change differential fluid while its up. Do a once around on the underbody. Wires, plugs if its time. Put that supercharger you always wanted in the rear...
Thats a filthy rumor. It IS necessary. No really.
Originally Posted by Zymosis
That, and the most important part, stay off the loud pedal. You don't have to practice your 60 foot time from every stop light.
Originally Posted by jimmyblue
'Vette rear O2s, these at least have a prayer of
working properly at low gas flow, lower exhaust
heat. Plus you don't have to buy extensions.
So,
Vette Rear 02's in place of front 02's on an F-Body?
Originally Posted by jinxedz
So,
