Drag Racing Tech
Starter for drag motor?
Old 01-07-2006, 06:11 PM
speedracerz's Avatar
Default Starter for drag motor?
what starters will fit an ls1? i am biulding a 13.5:1 motor and not sure if the standard aftermarket (csi or powermaster) 168 tooth starter will fit.
who has messed with this and what were your results
thanks
Old 01-07-2006, 07:17 PM
Tom the roofer's Avatar
POWERMASTER XS Torque for the ls1. I don't have a part number. I'm not sure if our sponsers carry them. I got mine from Summit awhile back. It's a heavy duty starter for sure Just ask for the above item.
Old 01-07-2006, 07:53 PM
found it thanks
Old 01-08-2006, 01:09 PM
1QuickT-A's Avatar
Cool.. I was wondering about the same thing yesterday..
Old 06-28-2006, 12:57 PM
gman's Avatar
Are you guys having any clearance issues with the powermaster starters.
Old 06-29-2006, 08:48 AM
ApacheDrill's Avatar
what did the part number end up being?
Old 06-29-2006, 10:21 AM
93LS1RX7's Avatar
I have a 14:1 408 that I use the stock starter for, it turns it over no problems as long as the battery is good.
Old 06-29-2006, 10:38 AM
gman's Avatar
pwm-9509 I found this at summit racing.
Old 06-29-2006, 10:41 AM
gman's Avatar
My stock starter just **** the bed. I am just looking for a good alternative.
Old 06-29-2006, 10:43 AM
Mine hasnt but i know its coming, once in awile when its been running awile and it gets hot.. it will just click over.. then when it cools down its fine. Same thing here 6.0 with a pretty big cam..
Old 06-29-2006, 12:36 PM
DopeFedZ's Avatar
Anybody know what the stocker weights?
Old 06-30-2006, 09:04 AM
93LS1RX7's Avatar
I am curious to see a side by side size comparision. I have VERY limited space down there and if that on is any bigger than stock I wouldnt be able to use it.
I would hate to spend $235 for something that doesnt fit with my headers
Old 07-03-2006, 02:38 PM
gman's Avatar
Unless my scale is off the stock starter weighed around 7 lbs. and the powermaster starter weighed around 8lbs.
Old 07-03-2006, 03:03 PM
gman's Avatar
Here is a side by side comparison:
http://i70.photobucket.com/albums/i9...tarters001.jpg
http://i70.photobucket.com/albums/i9...tarters002.jpg
Old 07-03-2006, 05:28 PM
SlickVert's Avatar
What is the weight difference?
Old 07-03-2006, 05:57 PM
direct bolt in?
Old 07-03-2006, 06:08 PM
93LS1RX7's Avatar
Thanks man that helps a lot. Looks like I should be able to fit it.
Old 07-03-2006, 09:28 PM
gman's Avatar
direct bolt in?
Yes it was a direct bolt in. It was tight getting it past the headers but it made it in. I only had one issue with it, after starting it up for the first time the starter ring gear wouldn't disengage from the flywheel. I then had to pull the starter and shim it with a supplied spacer. No big deal.
Old 07-04-2006, 08:43 AM
Pop N Wood's Avatar
Man, this almost looks and sounds like the same starter
http://store.summitracing.com/partde...5&autoview=sku
Was $143 yesterday. Today I look and it is $159.
