Too many cam choices
Ok guys, I've searched the archives and read opinions until my eyes hurt, but I'm still not sure what would be the proper cam for my application.
It's a stock 00 LS1 bottom end, 243 LS2 heads with 918 springs, ti retainers,7.40 hardened rods, a LS6 intake with custom long tube headers. This is a track car only, budget road racing. M6 with custom 5 & 6 gearing (.83 & .70).
3.73 rear end gears.
It's not going to see under 2500 rpm while on the track and it's a 2500 lb car so I'm not looking for huge low end torque.
It sounds like I can't really go wrong with a 224/224, but what lift? Or would something else better suit my application without porting the heads?
Too many choices...
Too many choices...
Originally Posted by just-a-z
change the spring to dual 921's and look into the MS3 from Texas Speed and the T-Rex from Thunder racing. Those seem to be the best peak HP cams on stock heads.
Ski
!LS1 11 Second Club
For roadracing, you want to stay away from aggressive ramp rate cams if you don't have the valvetrain to back it up. Aggressive ramp rates provide us with driveability and tq down low/mid. Great for street/strip, bad for roadracing (because of the added wear on the valvetrain). "Softer" lobes tend to come on hard in the mid/upper rev range. Lift is not so much of a crucial factor, as springs are designed with lift parameters in mind.
If it's a track only car, and you have 918's already :
Futral F6 226/230 .575/.595 112 (Semi aggressive lobes)
I spoke with Futral yesterday and they confirmed this would be a nice grind for RR.
Lunati has a couple RR grinds.
Lunati 230/237 .544/.543 112 (although it does have an aggresive ramp on the exhaust).
If you don't care about low end,
Lunati 237/242 .595/.595 112 (ramps not so aggressive) check piston to valve clearance on this one.
GMPP ASA 226/236 .525/.525 110 (Would work great with Vinci/Crane 1.8RR's)
!LS1 11 Second Club
I would use a comp xtreme RPM high lift lobe combo. 234/236 .576/.578 110lsa 108icl.
That uses a slower lobe that will live a long time with your 918's, give you great power from 2800-6300rpm, and like you said.. it's in a 2500lb car.
!LS1 11 Second Club
Originally Posted by SouthFL.02.SS
I'll call it the Gomer Road Racing Grind
That thing sounds sick.
By the way, just to be clear, you're talking about plain ol' XE lobes, right?
