Western Members CA, AZ, NV, UT, CO, NM, HI
Help, Socal basic tuning
Old 01-08-2006, 02:40 AM
jcgardnr's Avatar
Default Help, Socal basic tuning
I am about to have a shift kit, vacuum modulator, and a 3200 stall installed shortly. I am looking for a place that will do a basic tune for a reasonable price. At thunderracing they will do the following as a basic tune for $150:
• Setting desired idle speed
• Setting desired shift points
• Setting rev limiter
• Speedometer recalibration for different gear ratios
• Speed limiter delete
• Setting desired fan temperature activation
• Torque management delete
• Skip shift delete
• Rear O2 delete (OFF-ROAD use only)
• AIR/EGR Delete (OFF-ROAD use only)
Are there any places within 150 miles of Torrance CA that will do this for around that price? I would rather not send my PCM out unless I had to. Any help would be really helpful. Thanks.
Old 01-09-2006, 08:47 AM
12secSS's Avatar
I could do all that for less, and I am local. Hit me up and I can take of all of that in a few minutes this week.
Send me a PM.
BTW: you do not have Skip Shift, that is manual trans only.
Old 01-09-2006, 12:44 PM
jcgardnr's Avatar
Send me a PM.
Great! I will definately give you a PM. I know I do not have skip shift. I just copied and pasted the information from that site. Do you have any idea what the new shift points should be around with the converter, or do I just need to see what happens first after it is installed?
Old 01-09-2006, 02:01 PM
12secSS's Avatar
We will try it and see where it likes it after the converterr install. Typically about 6100 rpms should be fine.
Quick Reply: Help, Socal basic tuning
