16" procharger Fan?
16" procharger Fan?
Hi ,
I am about to install my Novi 2000 on my 01 SS,
I have to buy the procharger Fan shroud and a fan
I want to get a realy good fan, i heard the one procharger supplies is not that great.
What one should i get and will still fit into the procharger Fan shroud?
I also might mount a super thin 14"-16" fan on the front of my radiator.
Please help me out
Thank you
Please help me out
Thank you
I had a procharger fan....w/ my procharger. But I went dual pusher fans with my turbo set up and I have found the pusher fans do a better job cooling even with the turbo behind the radiator.
I'd go Dual Spal fans if you have to spend money on a fan.
Did you get your custom bracket for the head unit yet?
If so where did you get it from?
Does it have a spring tensioner?
Where does it mount the head unit?
How much?
Pics?
The Spal Fan your looking for is the 16" Spal Extreme 30100845, check ebay you can get them for under $200, usually go for $299. For the shroud call ATI.
How much?
Pics?
Originally Posted by MstgKillr
He is probably talking about the Flex A Lite 240's. I have tried both the pushers and the Spal Extreme 16". The Spal works better for me in Florida.
Easy to splice into your stock wiring and worked better than the single procharger fan.
IMO the biggest problem is the shroud- it blocks off half of the radiator making half of the radiator useless. That does not help things. I think the best idea is the addition of a 9" puller in the drivers side of the shroud as described in this post below. Be sure to measure for clearance. Good luck with your new set-up!
https://ls1tech.com/forums/showpost....8&postcount=43
how muh is that Flexalight 16" fan that pulls 3,300 cfm
I think i am just going to install the Procharger shroud with a 16" fan , and put another thin fan in front of the radiator and wire them stock
How do you think this will work?
And yes our radiators are way to small, GM did not put a big enough radiator in our cars
The SPAL 16" Extreme fan (3000 CFM) is a direct bolt-in and uses the same mounting hardware. That's what myself and another local Procharged guy swapped to.
I think Ed got his at a local ORW (Off Road Warehouse), and I got mine from an internet hotrod shop.
Rob (Bad30th)
Rob (Bad30th)
Rob (Bad30th)
Rob (Bad30th)
do i even need the Procharger shroud, will it afect the radiator at all
Lawnboy,
Let us know what kind of numbers your running when your done. And Please put up a video or sound clip when your done as well. I would love to hear how loud that Novi is.
If it works well for you, I might go that direction as well. I love my D1SC...but it a little loud for my taste.
