Cam bearing replacement
I'll be doing h/c soon and I'll be pulling the motor to make it easier along with a few other upgrades I'll be doing at the same time. I'd also like to replace the cam bearings, mainly for piece of mind during the swap. Does anyone have instructions and pictures about replacing the cam bearings on ls1's? What exactly is involved?
Thanks.
Thanks.
Originally Posted by wrencher
Removal of the engine is required. That is a precise installation that takes special tools & the know how to install them. That is generally a rebuild/overhaul operation.
LS1TECH.com Sponsor
You need a special Cam Bearing Remover/Installer Tool. Lisle Tools makes a kit, but if I remember correctly its around $200. Most will let the machine shop perform this task as they have the tool and have done many in the past. If you arent going to do it more than once, it really doesnt warrant getting the tool.
