Guages???
Guages???
Hello All,
I just got a couple autometer guages and I have a couple questions..
1) Where did you guys go through the firewall at??
2) Where did you hook up the power hookups?? Fuse box or another place?? Explain??
Thx for any help!!!
Thx for any help!!!
I was looking in the fuse box and I saw a spot that says ign with no fuse in it and it is a weird looking hole not like a normal fuse....can I run the power wireing into that??
Yes it is acc. power, only goes on when the key is in. You should be able to get a terminal to slide on to it. I think its called a spade terminal but I could be wrong.
