Belt Size for ATI Ballancer
Guys, do you know what length and/or part number belt will work with a 01 z06 corvette and the ATI Super Damper. It will be for a setup with air conditioning and is the 10% under drive piece. Thanks.
Mine came with belts, they were both Gates.
Serpentine belt: K060775 (21mm x 1980mm) under that number was 6PK1969
A/C belt: K040410 (14mm x 1059mm) or (9/16" x 41 3/4") under that number was 4PK1045.
Hope this helps.
Hope this helps.
Hope this helps.
Hope this helps.
Thanks a bunch!
