Finally, after months of waiting...
Finally, we have progress on our 346"/225cc ET head setup. The last 3 months have been very tough due to vendor setbacks and delays but the time has come. Last night after a hour or so of wrenching we were close enough to finally start the car and do the inital heat cycle.....
We topped off the coolant and filled the engine with some 5w30 non-synthetic oil. Made our last minute checks and pulled the fuel pump fuse. The motor sounded like an old 14.1:0 big block as the starter tried to crank the motor over, spun the motor once and stopped, tapped it again and just barely spun the motor over. Decided that wasn't going to work so we fired up the fuel pump and tried it again with fuel. The starter struggled to turn the motor over and after a couple of spins the motor fired. It idled nicely @ 1000 RPMs, oil pressure stable @ 50psi, injesting over 2.20 lbs of air per minute. We turned the electric water pump on and just let the car warm up and started adding transmission fluid to the freshly built RPM 4L60E transmission. After the coolant temps stabilized @ 165 degrees the idle dropped to a scant 750rpm. Considering we're running a 238/244 XER 112 + 2 cam thats pretty low without tuning, well without tuning for this cam. There is still alot of "detail" work to get this bad boy on the road but she is close. We're going to start installation on my Solid Roller 346 tonight! Stay Tuned.
Phil
Phil
Originally Posted by SouthFL.02.SS
238/244 XER 112 + 2
Setup:
Block:
LS6 Block
LS1 3.62 Crank
Scat H beam rods
Mahle Pistons -4cc and rings
Coated Bearings(Main and Rod)
Top End:
ETP 225cc 11 degree heads 56cc chambers
Coated 977 springs
Cometic Gaskets .040
Comp r lifters
8.100 Pushrods
FAST Ported intake
90mm NW throttlebody
Comp Cams: 238/244 XER 112 + 2
Exhaust:
TPIS headers
Random Tech Mid section
Bullet Rears
Misc:
Meziere Water Pump
Tranny:
RPM S5 4L60E
SS3800
3.90 Rear w/ Hardened shafts
Tires:
CCW Drag package
CCW SP500s 18/19
We're looking for a set of roller rockers for this combo...
Phil
Phil thanks for a run down on the set-up.
Looks like no rock was left unturned during the planning process.
That is definitely one first class set-up.
What kind of numbers are you expecting?
My calculations say 505-520rwhp
Phil
Originally Posted by Phil99vette
Charlie @ A & A Says 514rwhp using software
Phil
Phil
Good luck and keep us posted
Yeah thats it!
Setup:
Block:
LS6 Block
LS1 3.62 Crank
Scat H beam rods
Top End:
Coated 977 springs
Comp r lifters
8.100 Pushrods
FAST Ported intake
Exhaust:
TPIS headers
Bullet Rears
Misc:
Meziere Water Pump
Tranny:
RPM S5 4L60E
SS3800
Tires:
CCW Drag package
CCW SP500s 18/19
Phil
Setup:
Block:
LS6 Block
LS1 3.62 Crank
Scat H beam rods
Top End:
Coated 977 springs
Comp r lifters
8.100 Pushrods
FAST Ported intake
Exhaust:
TPIS headers
Bullet Rears
Misc:
Meziere Water Pump
Tranny:
RPM S5 4L60E
SS3800
Tires:
CCW Drag package
CCW SP500s 18/19
Phil
And what rear differential are you using? I have the DTE stage III with 3:90's and I'm using it with a mcleod twin disc. I hear that clutch will still punish my rear differential under hard launches. I'm worried!!!
Thanks......
Phil
Phil
OUt of a N/A 346? That will be completely insane!
Damn nice set up man........
Tranny:
RPM S5 4L60E
RPM S5 4L60E
Good luck with it Phil! I've been following along the last few months as you were working on both engines. I can't wait to see the numbers on both of them.
LS1 Tech Administrator
Phil
Phil
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Originally Posted by 00Vette
Hey Phil, aren't those 225 ETP heads too big for the 346?
Thanks......
Thanks......
Phil
225s too big for a 346??? Says who? Up until the AFR's came out 75% of the ported LS1/6 cylinder heads had over 220cc intake runners and don't flow comparable to the 225 ETP. The ETP also uses a longer port so the size is relative to port length. We're going to use their 240cc heads on my personal solid roller that is getting installed today and tomorrow. Both cars are going to run a 3.90 rear and a Ram clutch/SS3800 stall. The McLeod is one of my least favorite clutches on the market. There are plenty of clutches under $400 that work fine for the C5. Shoot, name one 6 speed car C5 that has gone 1.409-1.411 60's? I know of only one.
Phil
Phil
So when I get some new heads, do you think it would be better to go with the 225's over there 215's? I have the stock 346.
Should be some great combo's. Is the 3800 stall car going to be a N/A car or a nitrous car?? I can't wait to see some nitrous results with these heads. I've been thinking about these heads for my ride.
