caliper kit
That should work fine. Like anything take your time with the prep work (cleaning, sanding, grinding etc) and it will look great in the end. I used the caliper paint from Plastic-Kote.
Originally Posted by z28_n_tx
one more question..did yall remove the caliper completly..(brake pad, brake lines)??
should i clear coat it???
Just painted the calipers with the kit i bought and im not very happy withthe results...wish i had my cam so i could post pics....i used the paint that you brush on to the caliper and it just does not have the spray paint look (smooth)..im too lazy to sand that off and do the spray on paint so ill be leaving it as is for now..
