Heads and Cam?? Help :confused:
Old 01-11-2006, 08:35 PM
NW00SS's Avatar
Default Heads and Cam?? Help :confused:
I'm trying to decide what heads and cam to buy, and whether I should buy them in a package or not. I'd like to go with Patriot LS6 Stage II's and the TREX. My car only has 7k on it now, so I don't see a need to go any lower into the bottom end on the engine. Does anyone know what else I would need? Are larger injectors necessary? I plan on buying an LS6 intake, ported oil pump, dual roller timing set, plus all the other necessary items like bolts, gaskets, etc. Any one know exactly what I would need, I plan on having a friend of mine that works at a GM dealer do my work in my garage and he really knows his stuff. I know once I'm done, it will need tuning and I was planning on taking it to either Rapid Motorsports (closest shop to my house, maybe 2 or 3 hours) or LS1 Speed (about 10hrs away). Any and all help and suggestions are appreciated. I'm kinda on a tight budget being in school, but I need more power I plan on making it a dual purpose street/strip car. Thanks!
Old 01-11-2006, 08:47 PM
!LS1 11 Second Club
SouthFL.02.SS's Avatar
Do you have the necessary bolt ons to support the TRex? Long Tubes, ported TB, LS6 intake? UD pulley?
Is the car M6 or A4? Gear out back? Clutch?
Old 01-11-2006, 08:53 PM
NW00SS's Avatar
I have an M6, SLP L/T, SLP ORY or Random Tech Cats(i have both), Stock TB, 85 mm MAF, Getting an LS6 intake when I find one, Stock pullys, Either buying a 12 bolt but at the moment I'm attempting to build a 9inch b/c I have all the parts, Ram Clutch
If I think of anything else, I'll post it.
Old 01-11-2006, 09:44 PM
Ωmega's Avatar
Yeah, that cam is bad as hell, but you need a good support to run it well. Good intake, headers, exhaust. You'll need tall gears (4.10's or higher) would be good for the cam.
Old 01-12-2006, 08:41 AM
!LS1 11 Second Club
Well, make sure to opt for 4.10's/4.11's if going the TRex or TSP MS3 route. If staying with, say 3.42's, come down in size to like a Futral F11 or at most a TSP Torquer II. Good luck!
Old 01-12-2006, 08:52 AM
NW00SS's Avatar
That's the gearing I plan to run, I think I have a set of 4.11's right now, which willl work perfect.
Old 01-12-2006, 09:10 AM
JRracing's Avatar
I would get a nice pakage deal from one of the sponsors. And find something that fits your needs, like go fast but very streetable.
Old 01-12-2006, 09:13 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
You should be able to run the t-rex wiht no problems with that gear ratio.
Old 01-12-2006, 09:29 AM
ssmr0501's Avatar
Welcome Aboard Nick!
Old 01-12-2006, 10:05 AM
Allergik2dyin's Avatar
Whatever set-up you go with, rapid motorsports does an awesome job tuning ls1's.
Old 01-12-2006, 11:48 AM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
I agree Rapid does great dyno tuning!!
We just finished up a brand new version of our LS6 program that really flows big air! This port was designed to flow well with smaller valves as well as options for bigger valves. The intro pricing for the base LS6 head will be $849 & we have tons of upgrade options for the heads. You can get the heads prepackaged with your choice of camshaft such as the Magic Stick 3, Etc.. We have these heads ready to go so feel free to contact me if you have any questions!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 01-12-2006, 12:28 PM
Gunnar@Patriot's Avatar
We have several options on the 243 castings. Here are some flow numbers from a set of 243 castings with 2.00"/1.55" that we are shipping today.
.100" 75 / 62
.200" 154 / 121
.300" 215 / 165
.400" 254 / 200
.500" 285 / 217
.550" 292 / 221
.600" 301 / 226
These heads cost $1095.00 plus $30.00 shipping the US. It is a deal that is hard to beat.
Old 01-12-2006, 01:31 PM
NW00SS's Avatar
Thanks for the advice so far, I really appreciate it! You guys are a great help, I wanna do it right the first time!
Old 01-13-2006, 03:13 AM
NoGamesLS1's Avatar
http://www.livernoismotorsports.com/...t.phtml?p=1350 Just bought some of these. I havent seen anyone who can beat their prices
Old 01-13-2006, 11:55 AM
NW00SS's Avatar
What kinda cam did you run w/ the livernois heads?
Old 01-15-2006, 02:58 AM
NoGamesLS1's Avatar
Im going to run the asa hotcam with 8 1.85 rr. Its a 226/236 .525 110 lsa
