Gears & Axles - need a new driveshaft
View Full Version : need a new driveshaft
mcamarols1
01-12-2006, 01:53 PM
which on do i get??? mods in sig
MattZ28
01-12-2006, 02:35 PM
Most of the big dogs run this.
http://www.dennysdriveshaft.com/html/nitrous_ready.html
EPP
01-13-2006, 04:54 AM
We carry the PST 3.5" aluminum driveshafts, which come complete with 1350 U Joints, for $399.99. These driveshafts have a very high hp rating, check them out on my website. Bob
weestro
01-13-2006, 09:09 AM
Denny's.
TRex
01-14-2006, 05:48 PM
Well, you mods are pretty mild, so although Denny's is a great shaft, as well as the other one mentioned, they might be overkill for you application (read - heavier and more expensive).
Why do you need a new shaft ?
mcamarols1
01-17-2006, 09:23 AM
well the u-joint broke and i put a new one in, and now the driveshaft squeaks or something in the drivetrain. the reason i want a new one is i want to dump it at 4500rpms, will the stock one hold that kind of launch???
heres the pix of the u-joint
http://ls1tech.com/forums/showthread.php?t=434609
TRex
01-17-2006, 10:24 AM
Well, for that kind of launch with a stick I would go with the 3.5" alum shaft, or if you are going to mod it more or spray it later, look at the Denny's or a CF shaft.
INMY01TA
01-17-2006, 08:06 PM
Look for a used LT1 Or LS1 steel driveshaft. I broke the aluminum one in half at the track and wont go back to aluminum. They can be found cheap.
