CNC Ported 243 Budget Heads $865.00 Per Pair, Assembled
Old 01-12-2006, 02:36 PM
Gunnar@Patriot's Avatar
Default CNC Ported 243 Budget Heads $865.00 Per Pair, Assembled
While supplies last we are going to offer a great deal for a budget build up. Our CNC ported 243 heads assembled with 2.00"/1.55" OEM valves and LS6 springs for only $865.00 per pair assembled, no exchange !!
Here are some flow numbers on a set of these heads. Heads were flowed on our Superflow 1020, 3.905" Bore, using a clay radius, and pipe:
.100" 75 / 62
.200" 154 / 121
.300" 215 / 165
.400" 254 / 200
.500" 285 / 217
.550" 292 / 221
.600" 301 / 226
We offer a full line of heads that can be custom made for your application. Along with the 243 castings that are listed below, we also have our LS6 style heads, our LQ9 heads, and coming soon our new Predator castings. Not only can we give you many choices in your heads, we can offer options like Ferrea Super Alloy and Hollow Stem valves, 918 springs, additional milling at no extra charge, and our LS6 style heads can be made for chamber sizes from 59-72cc and bores from 3.905"-4.125" at no additional charge. When using our LS6 style heads, you can get all size chambers, with the heads at OEM deck height.
New Factory 243 Patriot CNC ported bare heads: These will be new 243 GM castings that are CNC ported with our stage II program and have our five angle valve job. The combustion chambers will be 64cc and extra milling is available at no extra charge. These heads will be bare with no valvetrain.
Pricing is $845.00 per pair, no exchange.
New Factory 243 Patriot CNC ported bare heads: These will be new 243 GM castings that are CNC ported with our stage II program and have our five angle valve job. Heads will be assembled with OEM 2.00"/1.55" valves and LS6 springs. They are the perfect head for a budget build. The combustion chambers will be 64cc and extra milling is available at no extra charge.
Pricing is $865.00 per pair, assembled no exchange.
New Factory 243 Patriot CNC ported heads with Ferrea valves: These will be new 243 GM castings that are CNC ported with our stage II program and have our five angle valve job. The combustion chambers will be 64cc and extra milling is available at no extra charge. These heads will be fitted with Ferrea 6000 series 2.02"/1.57" stainless valves. No springs will come with this particular option.
Pricing is $1,075.00 per pair, no exchange.
New Factory 243 Patriot CNC ported heads with OEM valves: These will be new 243 GM castings that are CNC ported with our stage II program and have our five angle valve job. The combustion chambers will be 64cc and extra milling is available at no extra charge. These heads will be fitted with OEM (non-sodium) valves along with our orginal Patriot Gold .650" Dual Springs, Ti Retainers, Super 7 Locks, Viton Rubber Seals, and Machined spring Bases.
Pricing is $1,095.00 per pair assembled, no exchange.
New Factory 243 Patriot CNC ported Stage II assembled heads: These will be new 243 GM castings that are CNC ported with our stage II program and have our five angle valve job. The combustion chambers will be 64cc and extra milling is available at no extra charge. These heads will be fitted with Ferrea 6000 series 2.02"/1.57" stainless valves, Patriot Gold .650" Dual Springs, Ti Retainers, Super 7 Locks, Viton Rubber Seals, Machined spring Bases, and Bronze Valve Guides. These heads are the best buy for the money. They are assembled with the highest quality parts at the best price available. When comparing apples to apples, you will find that these heads are simply the best value on the market.
Pricing is $1,395.00 per pair assembled, no exchange.
Old 01-12-2006, 02:50 PM
BADFNZ's Avatar
Size of intake runner? Any pics of the ports?
Old 01-12-2006, 03:09 PM
10secondZ's Avatar
thank god for the LS2 those are some amazing prices for sure!! flow numbers on the budget heads are very nice as well.Keep up the good work.
Carter
Old 01-12-2006, 06:19 PM
The intake runner will be 227 +/-. We will try to get some pics up tomorrow.
Old 01-12-2006, 07:13 PM
Bigrob339's Avatar
Are these the same head that are full 845 but have the OEM valve and ZO6 springs? B.C soon here I am going to buy a bare set for 845 and put some lightweight valves and my crane springs and ti retainers in the bare ones. But i guess my question is what valve will fit in the ones for 845 bare? because the 865 says they come with 2.00/1.55 valves, but the 1045 heads have the 2.02/1.57 valves. So will 2.02/1.57 fit in the bare heads for 845?
thx rob
Old 01-12-2006, 07:19 PM
Bryan @ Speed Inc.'s Avatar
DDDAAAAAMMMMMNNNNNN
Old 01-12-2006, 08:41 PM
ChucksZ06's Avatar
Gunnar I want a set of the 243 s with the oem ls6 springs. What do I do to order.
Chuck
Old 01-12-2006, 10:55 PM
just-a-z's Avatar
How do I get some?
Old 01-13-2006, 08:55 AM
zamboxl's Avatar
Originally Posted by imslow
DDDAAAAAMMMMMNNNNNN
i am saying
Old 01-13-2006, 09:05 AM
thx rob
We can do the valve job on the bare heads for either 2.00"/1.55" or 2.02"/1.57" valves.
Old 01-13-2006, 09:06 AM
Give us a call here at the shop for any orders.
Old 01-17-2006, 10:03 AM
Due to the volume of sales we have seen on our 243 CNC'd heads, we here at Patriot are happy to announce that we will begin including free GM MLS head gaskets and new OEM bolts on all of the 243 castings we sell. This is an excellent value for all of our customers. We would also like to thank everyone who has ordered from us.
Old 01-17-2006, 05:39 PM
gr8one99SS's Avatar
Does anyone know if theses heads will work good on a stock cid Ls1 with a F13 cam?
Old 01-17-2006, 06:07 PM
gr8one99SS's Avatar
anyone or bump
Old 01-17-2006, 07:33 PM
BADFNZ's Avatar
I think they'd match up well with that cam.
Old 01-17-2006, 08:14 PM
gr8one99SS's Avatar
thanks , what size cc or cr should i get
Old 01-18-2006, 10:52 AM
Yes sir, these will work well with the F13. We can mill these to 62cc which will give you approx. 10.8-1 compression.
Old 01-18-2006, 11:04 AM
SacLSWon's Avatar
Well I just recently, a week ago, purchased my heads through my local shop, Force Fed in sacramento CA. I cant wait to get them. <------ CANT WAIT! I am anticipating the phone call that they are in. Great product guys
Old 01-18-2006, 04:24 PM
Thank you, we are working on your heads now.
Old 01-18-2006, 04:51 PM
01350ss's Avatar
Would the $865 heads work with thunder's t-rex cam?
