402 + S88 = Muhahahaaaa
Old 01-12-2006, 07:34 PM
W8N2SQZ's Avatar
Default 402 + S88 = Muhahahaaaa
Heard last night from a little birdy that Borg Warner just dynoed a 402 with a Carbed manifold and a set of AFR heads. It made 1491 FWHP and 1297 FWTQ at 26 pounds of boost. Again, these numbers are at the flywheel and the motor made peak HP at 6500 RPM.
Also heard the turbo had room to go and that there is more testing going on with these CRAZY turbos Jose...oops...I mean this little birdy is making
Maybe my friend will chime in and give us more info
Glenn
Old 01-12-2006, 07:40 PM
BMW ///M Nerd
BAD ASS TA WS6's Avatar
Wow That's retarded HP. And to top it off it peaks at 6500?!?! Insane...
Old 01-12-2006, 07:49 PM
LS1Tech Sponsor
Superman09's Avatar
Wow, thatd be interesting to drive on the street, haha. I dream of having that kind of power......... After most of you guys move on and im the veteren of ls1tech, ill have that......someday
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old 01-12-2006, 07:51 PM
bboyferal's Avatar
I'm playing the lottery this weekend...
Old 01-12-2006, 07:54 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Nice. How do you calculate it at the flywheel, what was it at the wheels?
Old 01-12-2006, 08:19 PM
Wet 1's Avatar
PSJ, ever hear of an engine dyno? Have Ernie tell you about them...
Old 01-12-2006, 08:53 PM
LS1Tech Co-Founder
Hi Mr. Smartypants, I thought it was a running car.
Old 01-12-2006, 11:05 PM
LS1TECH Sponsor
JZ 97 SS 1500's Avatar
<-------tweet, tweet......lol
Jose
Old 01-12-2006, 11:13 PM
White.Lightning's Avatar
Jose
Will you just spill the beans already!!!!! hahaha
That is an impressive number. Pics/Videos?!?
Andy
Old 01-12-2006, 11:14 PM
W8N2SQZ's Avatar
Old 01-12-2006, 11:16 PM
LS1TECH Sponsor
White I did not dyno the engine......we simply built the turbo for it.
Old 01-12-2006, 11:23 PM
What are the specs on the turbo?
Race gas I'm assuming on the 402? Crazy motor in itself
Andy
Old 01-12-2006, 11:27 PM
LS1TECH Sponsor
Andy, nothing to crazy about the motor. Stenod, W2W and others are making big power with similar setups. LS1 crowd is just gun shy. If the 2JZ's can make 1400rwhp, LS1's should be able to match it....hehe.
The turbo uses an 88mm wheel, with monster shaft (designed for MUCHO abuse/boost). The turbine is the newer TM1 wheel. Its bigger then a GT47 turbine, but smaller then a GT55 turbine and flows like crazy. The trim on the wheel is a nice 86. The turbo itself is a mid-frame. This is the same turbo we use on our bottom turbo for our compound diesels making 100+psi.
JZ
Old 01-12-2006, 11:50 PM
W8N2SQZ's Avatar
Thanks Jose Anything else in the works you know about
Glenn
Old 01-12-2006, 11:58 PM
LS1TECH Sponsor
Yes, we have some smaller versions coming. They start from 70mm and go all the way to 88. Also we will have a T4 and T6 version with different A/R ratios offered.
JZ
Old 01-13-2006, 07:35 AM
NA$TY-TA's Avatar
JZ
So that bad boy was a T4 flanged turbo?????????
Old 01-13-2006, 07:50 AM
2001WS6Vert's Avatar
Is that an aluminum LS2 block?
Old 01-13-2006, 09:26 AM
IlEagle's Avatar
This turbo is a little larger than the GT47-88?
This turbo is not on your site yet, is it....?
Is there a ball park price yet for this turbo? Similar price point to the Y2K's?
Old 01-13-2006, 09:47 AM
GMC SKI's Avatar
It would be Nice to get some more info on this new series of turbos
Jose??
Old 01-13-2006, 09:55 AM
NA$TY-TA's Avatar
LESS..........
Quick Reply: 402 + S88 = Muhahahaaaa
