Edelbrock Victor Jr Fuel Rails
Anyone got pics of it with the stands they come with. I can't for the life of me figure out how they go. I don't have any instructions on them. Thanks fort the help.
Srun
Srun
Don't have any pictures, but "think" logically.
The lettering "Edelbrock" is on the outside.
There is four "U" shaped metal brackets and four small hex head bolts. -- they go into the small "holes" on the outside edge of the intake - almost on top of the injector holes.
There are four bolts with washers (2 regular and 2 locking) and four bolts with nuts.
Bolt up the U-bolts, bolt the rails to the U-bolts using the bolts and nuts.
Already set mine up and tore it back apart. Use a little lub to make the injectors "pop" into the rail and intake easier. -- You will see the rails slant slightly forward.
Hope this helps.
David
Hope this helps.
David
All of your pictures are of the trottle cable holder. These (only use one or two of them) are for the driver's side of the intake. Can't figure that I'll be using these. We'll be make a custom set. --- These are NOT the fuel rail holder - nor the one's I was refer'ing to.
David
David
