Is an LS2 pan better than an LS1 pan?
In my travels I heard that an LS2 pan has better oil control, holds more oil, and eliminates the wings. I believe it said the oil control was especially better under cornering.
Is that true?
Does an LS2 pan fit an LS1 without a problem?
Is that true?
Yes better, yes fit an LS1. here are some pics in this post
https://ls1tech.com/forums/showpost....19&postcount=3
Dont know if it will fit an f-body
Is that true?
Is that true?
I purchased an LS2 pan because I believed the hype and knew it would be much easier to pull my shortblock out of the top of my Vette (not dropping the cradle) without the wings of the LS1 style pan in the way. I ended up building a top tray with one way louvers (to let oil back in) and spent a bunch of time getting it to control oil at least as good as the pan I removed. The reason I decided to invest the time is I know I am going to be installing at least three different engines in this car over the next 2 years and I wanted the install and removal of all three to go smoothly from the top, plus, there is alot more room for custom larger tube headers if the winged pan was removed.
Anyway...to swap to this pan in a drag racing application would be a serious mistake, and to be honest, I dont think there is any application where it would shine over the original design.
Just my .02 and take on the situation...
Tony M.
