User Support & Resources - When I post it always has the sig in there...
2000 Tran Zam
01-13-2006, 01:46 PM
As a default.
Is there an option I can change to make it default to "not including the sig in every post unless I click the option for it"?
I tried checking in the user options and couldnt find anything.
cyphur
01-13-2006, 01:59 PM
Well, if you use the quick reply, there is a box in the bottom right you can uncheck that says "Show your signature" that is checked by default. In advanced reply there is a similar option as well.
2000 Tran Zam
01-13-2006, 06:18 PM
Ya, I know I can uncheck it, its just a hassle to have to uncheck it every time I post.
is there a way to make it as a default that it is unchecked unless I decide to check it?
cyphur
01-14-2006, 08:19 AM
I've never seen one. You can turn off signatures completely, so that you don't see anyone's.
The other option, is that you delete your signature. Then, it won't have anything to display. Lame option I know. But an option nonetheless. Otherwise, get used to clicking the checkboxes.
I'm kind of surprised there's not an option for that. Pretty sure there is one in other message-board software. Maybe it'll be an added feature in that vbulletin upgrade we're supposed to eventually be getting. :)
2000 Tran Zam
01-15-2006, 12:17 PM
I sure hope so. I know that is the default with ls2.com's webpage.
Maybe Tony or one of the admin's can contact eboggs or zed over there and ask more about it?
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
