Only one stripe?
Only one stripe?
Got a 1998 TA automatic, from the code on the door (GU2) it has the 2.73s, with traction control. When I turn the tcs off and do a burnout, only one wheel leaves mark. I would expect both to spin, whats up with that?
JD
JD
So Im going to change my Rear end fluid in the next couple of days.
Im having no problems with the rear except only one wheel spins when I burn out on the road.
Is there anything I would be able to see (not knowing anything about differentials) inside there that could be causing this?
or should I just take it and have it looked at?
Oh also, my speedo is off, and I was told the only way it could be off is if the previous owner changed something in the rear?
